непрочитанный 02.12.2008, 05:55
Ответ: Для любителей Counter-Strike'a 1.6
К слову нашёл я апдейт для рэйс-икса:
Locke has updated RaceX
RaceX - Race Factor V1.25 Update
just extract the archieve including folders to your rF directory overwriting older files
Alteast V1.2 is required for this update to work corectly !
Changes from V1.2 to V1.25:
- changed: raised front wing drag on BMW 320si a little bit, was too low compared to the generated downforce
- changed: default rearwing setting on BMW 320i & 320si from 2 to 3
- changed: small changes to brake heating/cooling
- changed: brake response to temperature slightly changed - be carefull when leaving pits with cold brake's !!!
- changed: small tweaks to make the 2007'er cars more competitive with each other
- changed: 2007 BMW 320i E46 weight from 1150 kg to 1140 kg - Minimum weight for RWD car and H-Shift Gearbox, No Ballast, Including the Driver + Fluids
- changed: some changes to the upgrade ini's of the WTCC 2006 cars for better mixed class racing (2006 vs. 2007)
- fixed: typo in BMW Mini suspension file
- fixed: 06&07 BMW 320si E90 Upgrade .ini's - the "Zanardi-Model" was missing a upgrade option
- fixed: undertray points on 1987 Alfa
- fixed: undertray points on BMW M3 E92
- fixed: undertray points on SEAT Toledo
- added SEAT Leon TDI - thx to Patrick Ziller
- added Vauxhall Vectra
the Vauxhall vectra is not available as seperate addon anymore as it's part of the full package from this patch on. The TDI could use better sounds, if anyone is up for the task just drop me a message. The graphics update is still in the works and will follow later.
Вообщем из нового дизельный фольц и вектра + немного фиксов и подстроек
Ежли есть желание поставить то: http://www.megaupload.com/?d=XI2PZ3ZG (на файл-фронте ссылка мёртвая) либо с меня: http://www.npfpol.ru/rfactor/RaceX 1.25 Update.7z (23 метра)
Но насколько я понимаю его надо ставить сразу всем
Собсно вопрос - ставить бум или нет ? ничего особо полезного в апдейте нет но и весит он символически
непрочитанный 02.12.2008, 08:07
Аватара для Mark
Mark Адекват
Охренеть!
Нашел трассы:
SINe, жжошь!! Просто зачод!!
Выходные 1...10 января объявили длинными. Буду с вами.
непрочитанный 02.12.2008, 11:23
Аватара для samolet
samolet Адекват
лучше не ставить ща ап - пока народ не вкатался
ЗЫ
http://www.npfpol.ru/rfactor/Ahvenisto1.0Final.7z 9 метров
http://www.npfpol.ru/rfactor/Alastaro_1.1_Final.7z 18 метров
битые архивы
BMWололоrc (ц)
Последний раз редактировалось samolet, 02.12.2008 в 11:25.
непрочитанный 02.12.2008, 13:55
кто готов поделиться дистрибутивами???
сейчас нахожусь на лесной.
могу подъехать после 17 куда надо с флешками и переписать
непрочитанный 02.12.2008, 13:57
Аватара для samolet
samolet Адекват
вечерком в районе 21-30 (+/- трамвайная остановка) можешь подъехать ко мене переписать
BMWололоrc (ц)
непрочитанный 02.12.2008, 14:04
samolet, блин... так играть начинают в 20-30...
да и ехать не на чем....
непрочитанный 02.12.2008, 14:31
я сейчас чутка помучаю хондо и пойду нафуй спать (36 часов ударного вкалывания ) так что сегодня вечером мну не будет
дистрибутивы могу скинуть но завтра
непрочитанный 02.12.2008, 14:48
Аватара для samolet
samolet Адекват
ну - с доставкой на дом - вряд ли
BMWололоrc (ц)
непрочитанный 02.12.2008, 14:50
samolet, а за пива???
непрочитанный 02.12.2008, 15:05
Аватара для samolet
samolet Адекват
я не потребляю пиво
BMWололоrc (ц)
непрочитанный 02.12.2008, 15:13
samolet, есть много яблоков
ужином могу накормить...
Аватара для SINe
http://maps.yandex.ru/spb?upoint=81794e483eae
Если сюда подъедешь - будет тебе щастье!
Апдейты пока не ставим. Иначе придется ставить всем. Попозже...
Последний раз редактировалось SINe, 02.12.2008 в 15:16.
непрочитанный 02.12.2008, 15:17
а куда там именно?
непрочитанный 02.12.2008, 15:21
давай я в 17 выйду сяду на 10ю маршрутку... и она туда меня домчит
непрочитанный 02.12.2008, 15:43
Аватара для SINe
Оке!
Джедай тут с отключенным орком через аську телеграфирует. У него есть находка. Он дарит её всем нам!
iluha ! (15:37:34 2/12/2008)
этор мяково)
http://www.rfactorcentral.com/detail...%20Ring%202007
И еще передает трассу Top Gear:
Последний раз редактировалось SINe, 02.12.2008 в 15:45.
Часовой пояс GMT +3, время: 10:49.
